oil and water
oil and water
on the right side by the AC compressor i see oil and when the car sits oil accumulates on the ground i add a gallon of water every two or three days it is not the AC compressor AC works fine and maintains pressure
any idea what i am facing
Received 3,812 Likes
St. Jude Donor '03-'04
could be lots of things, or a combination of things..
changed oil 2 days ago today let car idle for 20 mins and about 2 oz of fresh oil on the ground no smell of coolant but i do see oil and water on the right frame rail by water pump no leak there
These are both serious items that could cost you a motor. If you not able to find the cause of both of these problems you need to take the car to a Corvette shop or even a Hot Rod shop. I would stay away from the dealership. If you take the car somewhere you have to make sure your oil and water levels stay OK during the trip to the shop. A new LS motor does not come cheap, be careful.
