Cleaning under battery tray area!
Hey guys my 97' C5 is about as clean as you can get under the hood, except in one area that is really bugging me. I've replaced the AC Delco battery with an Optima Red Top gel cell battery about 6 years ago (still going strong) because I've heard about batteries leaking and destroying the pcm & wiring. I really want to remove the battery, and clean inside this area really well as it has some "dirt" etc on the wiring and plastic down there. I know you are NOT supposed to get this area wet, so what do you guys use to clean the battery compartment area? Thanks!
The simple green won't eat away at the plastic wiring harnesses? I have purple power but that stuff is WAY too strong... You dont have to wash off the simple green, you can't get the pcm or wiring correct right? Also random question, but the fuse box panel bolt with plastic head has always been missing, where can I get one? Thanks!
If your batt wasn't leaking, there won't be much to clean except dust and like Nuke said, leaves. Simple green will not hurt plastic or wiring etc. Just spray it on your rag if worried.
If your batt was leaking, I have no suggestion for you.
I caught battery acid leak in early stages.
Connectors and wiring is waterproof.
Remove RF wheel and remove access panel at rear of wheel well. Plastic bowl full of warm water/baking soda mix liberally poured all over everything a couple times, rinse with fresh water, let dry. Sand/wire brush/clean as/if needed the spray paint where needed.
Raymond Shartrand (05-29-2023)
I removed the inspection panel to have better access and used baking soda/water mix as I found early signs of acid leak. The seepage was from the OE Delco battery back in 2000 or thereabouts.
I agree with Lonestar on the Baking Soda mix w/warm water. I used a bristle brush (plastic) and scrubbed the area good with that stuff. You'll see foaming, which is telling you the acid it being neutralized. Keep going till you no longer see any foaming near your weld or metal seams.
I then let mine dry a few warm days in summer, and then spray painted. Much of the paint on my frame was gone.
Mixed up about 2 gallons of baking soda and hot water
Remove battery and tray and liberally wash everything under the tray with baking soda and water solution. Will see bubbles as it neutralizes the acid. Also clean the tray, bolts, battery hold down etc. with baking soda solution. Rinse with a garden hose and flush out all the baking soda solution. Let dry and repaint any metal that the acid got to. Then you can replace the battery tray and battery. My vacuum hose was shot too so I had to replace most of it with windshield washer hose.
Battery tray is molded plastic. Acid proof. Just clean and re-install.
The clip-on metal "U-Nuts" used for mounting it however, can be corroded or rusty. They are a larger size IIRC and I didn't want to go on a search to find the "correct" ones, so I just cleaned and hit them with a wire brush them black paint. Same for the mounting bolts.
I still soak the plastic parts to neutralize the acid
