washer fluid leak by wiper arm
Old 03-03-2013, 08:30 PM
c6miller
c6miller's Avatar
Default washer fluid leak by wiper arm
I frequently notice what I believe are a few drops of washer fluid in the cowl area by the passenger wiper arm where the washer hose is attached. Is the supply hose replaceable or would I need a new wiper arm (which I have no idea how to replace). Can anyone please shed some light on this for me. Thanks
Old 03-03-2013, 08:49 PM
dmarkshark
dmarkshark's Avatar
Probably just need the hose, definetly replaceable. Just pull it off and check for any cracks or splits on the ends.
Old 03-03-2013, 09:08 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
Replacing neither will make a difference. The fluid pushes out during acceleration. There have been many threads on this forum about it. If it bothers you, there is a one way fluid diode that Ford uses that you can put in the hose. There was a part number given to buy the correct part, but I don't have it handy. I'd go to Google and type in C5 Corvette washer fluid leak, you'll probably come upon it.
PS. All C5's do it to some extent, it's not a broken part causing it.
Old 03-03-2013, 09:31 PM
dmarkshark
dmarkshark's Avatar
Haven't had it happen on mine?
Old 03-03-2013, 10:22 PM
65GGvert
65GGvert's Avatar
The fuller the reservoir, the more likely you'll get it. It's just a few drops in the cowl area. It dries and leaves little spots if you don't dry it. I've never had one that didn't.
Old 03-04-2013, 03:39 PM
sccs
sccs's Avatar
This happend to me, after a few weeks washher fluid pump got some error blowing out all the fliud out, when tere was no fluid left pump became sooo loud it was scary. i parked and disconected the pump. a nearby lady even asked me if its going to explode.. crazy stuff
To washer fluid leak by wiper arm
Quick Reply: washer fluid leak by wiper arm
