My HVAC not turning on and ABS/Traction Control lights on?
My HVAC not turning on and ABS/Traction Control lights on? Solved :)
Hello,
I have a 2003 Z06 and am having some issues with my HVAC and ABS/Traction Control. I am not getting power to my HVAC control and at the same time the ABS and Traction Control lights are on. The HVAC has the dimmer lights, but no control power. I have checked the fuses and found no issues. Any help would be great.
Adam
Adam
Hello,
Adam
Adam
http://www.stengel.net/diccodes.htm
Need dic codes. This link describes how to get them,
Ok I went and got some codes doing it the way Big Gun mentioned...thanks again There are a ton, but I wrote down a few.
P0135
p0141
p0155
p0161
p1571
p1689
TCS no comm
HVAC no comm
b0507
b0508
b2482
b2527
b2587
b2208
b2228
b2248
b2207
b2592
b2593
b2723
b1096
u1096
u1255
BCM:
b0432 h c
b0502 h c
u1096
After I cleared all of the codes, two remained:
B0432
U1040
Any help would be great. It seems there may be a communication issue, where should I look?
Thanks again
Adam
P0135
p0141
p0155
p0161
p1571
p1689
TCS no comm
HVAC no comm
b0507
b0508
b2482
b2527
b2587
b2208
b2228
b2248
b2207
b2592
b2593
b2723
b1096
u1096
u1255
BCM:
b0432 h c
b0502 h c
u1096
B0432
U1040
Thanks again
Adam
P0135
p0141
p0155
p0161
p1571
p1689
TCS no comm
HVAC no comm
b0507
b0508
b2482
b2527
b2587
b2208
b2228
b2248
b2207
b2592
b2593
b2723
b1096
u1096
u1255
BCM:
b0432 h c
b0502 h c
u1096
B0432
U1040
Thanks again
Adam
P0135
p0141
p0155
p0161
p1571
p1689
TCS no comm
HVAC no comm
b0507
b0508
b2482
b2527
b2587
b2208
b2228
b2248
b2207
b2592
b2593
b2723
b1096
u1096
u1255
BCM:
b0432 h c
b0502 h c
u1096
B0432
U1040
Thanks again
Adam
Ok I think I have fixed the problem. I have not had much road testing with it yet, but it appears to have fixed all of my issues all at once. Here is the link for what I did in case anybody else is having issues. Good luck http://forums.corvetteforum.com/c5-t...ch-repair.html
