Clutch pedal adjustments?
Hey all,
I am curious if there is a way to adjust the stock clutch pedal.
My issue is I am average height (5'10") but I tend to sit back in the sit and with the seat moved more to the rear. This position leaves me fitting in the car perfect with the gas and brake pedals, along with the steering wheel.
The problem I have is that reaching the clutch pedal is ok.... UNTIL I have to press it in. Then I find myself reaching far to push it in to a point that it engages.
This causes me to scoot down in the seat to press the clutch in to start the car.
This causes me to not fully engage the clutch when i am driving and at times not allowing the gear to engage when shifting.
I definitely have issues with trying to engage the 1st and 5th gear
I thought maybe there was an adjustment to allow it to engage more towards the top of the pedal (aka, less throw of the pedal needed to engage). I am also wondering if there is away to adjust the clutch pedal starter switch.
Basically I want to make driving the car easier
Your answers appreciated
You can buy a tick adjustable master cylinder. you shouldn't need to press it too far to release the clutch though. try bleeding and changing your fuild before dropping the money on a tick master. How many miles is on your current clutch setup?
I would honestly spring for the Tick MC anyways. That is an adjustable MC and the stroke is shorter than the stock unit. The Tick MC is a superior MC than the OEM and other aftermarket MCs, which happen to use the same OEM body as the factory MC.
I appreciate the info, but I am actually trying to adjust the pedal.... not how the master cylinder engages the pressure.
Basically what i am saying is.... my leg is too short for how I sit in the car to work the pedal correctly.
It is almost like if I could move the pedal forward some, add a block of wood to it or something to make it more available to my left legs reach
"What I'm saying is....my leg is too short for how I sit in the car to work the pedal correctly"
Hope this may help.
http://www.shop.bondraperformanceeng...orEZClutch.htm
Hope this may help.
Hope this may help.
Hope this may help.
Just wondering if there is a way to make a show throw clutch pedal.
Basically, leaving the pedal in place as it now but changing the distance it needs to move to fully engage the master cylinder.
I have done this before in other cars.
Adjusted the clutch pedal....
So instead of say pushing the pedal in 3 inches to engage the clutch fully, you only have to push it in 1 inch.
Which usually meant you were engaging the clutch at the top of the pedal swing.
Any help would be great
well actually the tick mc does reduce the amount of travel needed for full engagement, but I would probably talk to tick 1st, or go the route already suggested by bumble-z
I can only assume that the clutches that you've adjusted in the past were not hydraulic systems. The older cable style clutch linkages allowed for pedal placement. To the best of my knowledge, hydraulic systems with masters and slaves do not.
Thanks guys,
That might be my issue (cable/mechanical vs. hydraulic). Might be the reason why I am like "I know I can do this, but how?" and you guys are like "what the heck is this guy talking about" hehehe
I will call Tick and see what i can come up with. i have already figure out how to make an adjustable clutch stop. I am sure i can figure this out :-)
The Tick is DEFINITELY NOT the solution here. With the Tick master, everyone I know ends up with a clutch pedal that sits lower than stock. You adjust the Tick for proper disengagement - not pedal height. They are very specific about this. The reason being, if you adjust the Tick for pedal height, you will over extend your slave cylinder or blow the hydraulic quick connect in the clutch line. It has happened a number of times on different forums.
I run a Tick master and it's a great master cylinder and corrects a problem with the stocker and aftermarket clutches. Yes, mine does sit lower than stock - properly adjusted. It took about 5 minutes to get used to it.
Cartek made an adjustable stock master. They cut the rod and welded on an adjustable with a heim joint end. It worked well but when I changed clutches, I went with the Tick to try to get the Spec 3+ to shift. I now run an RPS CC Twin Lite clutch.
