What clutch/flywheel is interchangeable?
I know the LS7 clutch and flywheel will work on the LS1. But will the LS3? LS2? If so, what flywheel is needed?
Also, I assume if the stock LS7 clutch works on the LS1, an aftermarket LS7 clutch and flywheel should work as well correct?
1 Post
St. Jude Donor '14
I run a stock LS7 flywheel because its lighter than a stock LS1. From my understanding as long as the mating surfaces match up, bolt patterns match, and your clutch is balanced to the flywheel then your fine. you can take the clutch and fly wheel to a machine shop and have it balanced.
I was under the understanding that the LS7 flywheel was heavier.
