p0440
p0440
I got my 2001 z06 a few months ago, and ive been plagued with a p0440 CEL. its always on startup, never while driving. several multiple hour road trips and never has it come on, but ever 3/4 startups it kicks on. havent replaced the gas cap but its always tight and i read that p0440 indicates a bigger leak than gas cap. Occasionally there is a faint scent of gas, but nothing major. anyone have a diagram of the evap system? ive got a scan tool, is there anything i can do to further diagnose the problem with that? thanks in advance.
well, even though no one replied, i figured i would post back with an update in case anyone in the future suffers this same issue. pull your drivers side engine cover off and look for a vacuum port right around the coil pack closest to the firewall. theres a connector that has a vacuum line that runs towards the front of the engine. (if you arent sure its the right one there should be a green tag that says evap emissions regulated at 1 psi or something like that.) mine had come disconnected there causing a strong unburned fuel smell through the vents and a p0440 CEL.
The following 3 users liked this post by dbgoodwin:
Nice! glad I posted my update after finding it. I was such a "Duh" moment when I saw it that I was almost skeptical that I had found the actual issue.
