C5 STS Turbo Kit
05-08-2013, 04:28 AM
C5 STS Turbo Kit
I have an STS turbo kit for a C5 and I need to know what I need to do to the heads so I dont blow a gasket when I kick on the turbos?
05-08-2013, 06:13 AM
05-08-2013, 08:04 AM
If you're running low boost, 7psi or so, you shouldn't need to do anything special with the heads/gaskets.
You will need to re-do your PCV system, do some searching on it. Make sure you find a good tuner...
05-08-2013, 09:18 AM
Quote:
Originally Posted by
PhysicsDude55
05-10-2013, 02:44 AM
Okay, thank you very much!!
