Normal idle RPM?
Normal idle RPM?
Yesterday I noticed I had a unusually high RPM at idle. ( 950- 1000) So I took off airbridge, MAF, and connectors. Cleaned the MAF, then re-connected everything. Now I am down to around 725-750 RPM at idle with the A/C off. No codes are showing. I suspect that I had an air leak in addition to the dirty MAF. So my question is - Is 750 RPM idle speed normal for my C5? Thanks for a response.
99 Vert, 6 spd manual, Magnaflow axle back
