Sparks from starter buy new or buy a solenoid
Well my starter has been having some issues lately. Sometimes the car won't start at all and had to take a few extensions and give it a whack and it would be gtg for days. I was doing this for awhile for a few months now. The starter is not oem but about 4 years old(had a shop here changed it after some other issues not starter related) got headers 2 years ago also. And had some wires start to melt down a few months ago. Starter wires looked fine had to redo the CPK sensor and oil light(behind starter). Few months later now last week the starter would not engage and I could see sparks coming from it(never did that before) while turning over which was sounded crazy and looked crazy. More whacking and it would start. It's in the garage thinking about just ordering a solenoid..What do you guys think? Battery is new about 1 year old and works great
where can you get solenoids and what do they cost? no where i've checked lists them
ac delco 1922a is the reman starter and something like $130 shipped on amazon
since you have headers another option may be a parts store starter. quality sometimes sucks but the lifetime warranty makes a change out easy.
starters seem to die a lot more frequently on header equipped cars
Chicago1,
you didn't mention what brand starter you had put on before your headers were installed.
All this rap a tat tat with an extension is nothing short of Half A--
Take your car to a shop that really knows what they are doing & have them put in a brand new GM starter & have a starter blanket ready to go on at the same time.
It's not going to be cheap with the headers in the way.
Who ever installed your headers, sure didn't go through the trouble in making sure that the wires around the area of the headers were pulled back & insulated from the heat. This will only cause problems sooner or later.
Chicago1,
edit: 17 bucks with shipping..
http://www.ebay.com/itm/Chevy-V6-V8-Starter-Aluminized-Heat-Blanket-Mat-Heat-Shield-High-Temperature-/111073565770?pt=Motors_Car_Truck_Parts_Accessories&hash=item19dc801c4a&vxp=mtr#ht_2504wt_932
if you have headers that pictured blanket really should go on
heat is the #1 cause of starter failure and headers add a lot to that area. even if you had your headers ceramic coated, that helps but the blanket is a cheap life extender
I rebuilt dozens of GM starters in the "old days" when you could get parts NOT NOW
Rebuilding a GM starter consisted or removing solenoid, cleaning up contacts or replacing solenoid, removing rotating communtator and cleaning the contacts, replacing the brushes, replacing the gear that contacts the flywheel. Almost impossible to get the replacement parts nowadays. Since the Corvette starter is a bitch to remove (have to drop exhaust) when I had bad contacts on the solenoid or communtator I simply acquired a rebuilt GM starter and swapped it out in one shot.
Got the started for about $120 and paid someone another $100 to drop the exhaust and replace it. If you have the means to drop the exhaust and play swapping parts go ahead but since it is a PIA to get to it I thought otherwise,
exhaust isn't that bad on jack stands. it's only the front section that has to come off. you can then scoot the mid pipe back enough to clean the manifold studs and drop down.
an impact gun and deep impact swivel sockets are more or less required
my little 3/8" matco gun worked like a charm. didn't even need the 1/2 to break the studs loose
I have a slip fit exhaust so the whole exhaust has to come off from the axleback to the headers. It's a pain but I have done it before a few times when my crank position sensor melted. SO the solenoid is not just a plug and play? I have searched and there isn't a how to or much about swapping it out. looks like I may take some pics. I start sabbatical tommorow so I'm off until August 11th so I have lots of time to do this.
I ordered a new solenoid. The wire that goes from the starter motor to the solenoid was loose causing the sparks because the nut was loose. Figured I'll tighten it down when I tried it broke off can't be fixed. I'll let you know how it goes.
wonder if that was the problem all along?
well, since you have a new solenoid and that's what usually fails, they don't look too hard to change. throw in the new one and see what you get
Well just finished it. Im waiting for my 02 and harness but I figured I could do a quick start while I wait on parts. Sure enough it started like a champ so it was the solenoid. Its a easy swap. Basically its 3 screws that need to be taken out. Hard part was getting a deep long 4mm socket. I tried a few places but finally got one at sears. Basically you take the 3 screws off. Lift the solenoid back and up and viola she comes off. Put the new one on put the 3 screws in and your done. It literally takes 2 minutes to do if even that. Taking the starter out when you have headers with a slip fit exhaust is the crappy part. But 24 bucks vs 200 is a win in my book. PS...It may not be a good idea to start your car in the garage with open headers at 1030 in the evening in a very quiet neighborhood ....
i kept my oem starter for just this reason. it still had *****, just wouldn't engage sometimes. suspected the solenoid. i'll get one of those 25 dollar ebay solenoids and refurbish it sooner or later.
have a new ac delco in the car now but it never hurts to have 2
i love having spare parts on hand
