Help Diagnose Grinding Noise from Driveline
Does this sound like an axle noise to you? Video:
History is I bought a 2003 C5 Z06 a few weeks ago. It has a number of problems, including an intermittent grinding noise from the rear. The transmission was just rebuilt, new torque tube bearings installed, and a new differential was installed prior to my purchase. It was obviously slapped together in a hurry without much care.
The noise is present with the rear wheels rolling, even with the engine off in neutral, so I figure it must be a problem from the output shaft back.
I put it on the lift and saw a leaking right axle. But I'm not positive that is the source of the noise. What do you think?
Leaky Axle:
Hmmm...I doubt this clamp is supposed to be empty.
Somehow I think something else is supposed to be in this spacer?
Missing bolt.
Loose mid pipe
Missing torque tube bolt.
O2 sensor wiring burning on header.
AC hose sleeve touching header.
Leaky Axle:
Missing bolt.
Loose mid pipe
Looks like someone was burning the midnight oil before they sold this. Either way its still an amazing car keep your head up. I am sure someone here can give you all the info you need.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have more exhaust leaks than I can count,, Sounds like a farm tractor
I would get the exhaust properly sealed up and we can get a better idea of what it sounds like
I did hear a bad noise when the wheels coasted down and to me it sounded like a bad wheel bearing. Grab the wheel in the 12:00 & 6:00 position and push /pull
There should be no slop or free play. Same for the front wheels.
Your CV Joint boots also look damaged. Wipe off the grease and see if the boots are split.. If so, replace the CV joint with a rebuilt unit form the auto parts stores.
BC
BC
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try this:
Jack up the rear. Have some one HOLD one rear wheel. See if you can turn the other one.
If everything is working correctly, you shouldnt be able rotate it to or it should take a lot of force to move it AND, there shouldnt be any slop.
You'd be amazed how sound carries with these things. I don't have any sound while I'm at work, but I ended up having a bad front right wheel bearing that caused what I (and 275$ later, a Corvette "Speciality" shop) KNEW was a bad diff. I got the diff rebuilt and the noise was still there. I eventually said "screw it", and replaced all the wheel bearings. Smooth sailing from there.
Thanks for the help. I'm surprised everyone is saying wheel bearing. I'm not detecting anything on the wheel movement tests, but I've had several bad wheel bearings in my lifetime and never once detected it that way.
None of the bad wheel bearings I've had before sounded anything like this. But those were on other cars - this is my first time working on my own vette . This noise is awful and my gut is saying transmission, but I'd really like to have a plan of action before I rip the driveline apart.
I fixed the exhaust leaks and made another video. I move the phone around so hopefully you can tell that the noise is much louder around the transmission/differential area.
It really doesn't sound like a wheel bearing to me. Try using a stethoscope or the screwdriver to the ear trick and see if you can isolate a component. To me it sounds like you have spare parts in the differential, but I am probably misreading the video.
I'll try a stethoscope, if I can figure out where to get one quick locally
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Car on lift, ENGINE OFF in first gear: rotate one of the rear wheels CW and then CCW. See if there is ANY lost motion. There should be very little. Then check the other one.
What does the drive train sound like with the car on the lift, trans in N engine running clutch out?? And then clutch IN.
Theres a BUNCH of lost motion somewhere! My first guess would be the rubber couplers in the torque tube.
BC
BC
And then clutch IN.
Got a stethoscope, and it's still hard to tell if it's differential or transmission, but I think it was loudest when pressed up against the rear of the transmission case.
BTW I now agree that a wheel bearing is likely bad, but I think it's not the main problem - just another one among the 99.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well. You are probably NOT going to like what I am going to tell you to do:
I would disassemble the entire thing from the bell housing back and reinspect ALL the work.
With all the HACK jobs that you posted, I wouldn't trust ANYTHING.
Its sooner or later going to POP and leave you stranded and BROKE! Fix the issue before it goes catastrophic
Remove the trans/Diff as one piece from the TT and then the TT
If it were me,, I would even remove the clutch. and male sure that the Flywheel bolts are properly torqued and locktited in mplace...
BC
BC
BC
BC
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The Differential is EASY to open and inspect. Here are two or three post that you should take a look at. I did the C6 up-grade and it worked out excellent.
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 ragtopws6, T-56 Build (what’s in my tyranny?) : http://forums.corvetteforum.com/nort...-smoother.html
The trans can be checked for lost motion after you separate it from the Diff and TT
I recommend taking the TT apart and checking the bearings and rubber couplers
BC
BC
I said throw out bearing... When we pulled the trans the second time
FWIW I did pull and put in the trans/rear on this car twice. I was there when it blew. I know the car well.
I have some exhaust hangers that I wanted to put on there.
It was never my car, but I know a ton about it. If you want to PM me, maybe we can work together to find the problem.
And just to throw it out there, the guy that sold you the car is a standup guy. I was fairly sure he told you about all of this when you bought it...?
