Reads low coolant level when not. Bad sensor??
Old 06-09-2013, 07:53 PM
nyelectrify
nyelectrify's Avatar
Default Reads low coolant level when not. Bad sensor??
I've got a 98 and after changing out all the coolant and flushing the system along with transplanting the coolant level sensor to a new coolant reservoir it now keeps reading low coolant level when it's not low.
Bad sensor???
Looked fine when I pulled it out and checked it
Input would be appreciated
Old 06-09-2013, 08:21 PM
nyelectrify
I don't think so, the new tank came without one and the old tank with sensor out looks exactly the same, the sensor has a rubber o ring to seal it just like electrical connections do in the cars. And you push it into the tank opening for it and then plug on the electrical connection.
I was trying to figure just how it works though.???
Old 07-15-2013, 09:27 PM
Dads C5
Dads C5's Avatar
Bad sensor???
I have same issue with my '98. Did you figure it out?
Old 07-15-2013, 10:37 PM
dblerman
dblerman's Avatar
Wrong year tank.
The 00-04 tanks likely use the same molds as the early tanks, but the spot where the sensor gets installed is sealed off on the 00-04. You can not simply swap the sensor from a 97-99 to an 00-04 without modifying the tank.
Old 07-15-2013, 10:38 PM
dmarkshark
dmarkshark's Avatar
I have a 99 and the sensor was part of the tank, the newer ones don't, could be wrong on that. But, you probably got the wrong tank as mentioned.
Old 07-15-2013, 11:15 PM
Tusc
Running Guns & Moonshine
Support Corvetteforum!
Tusc's Avatar
Received 3,284 Likes on 1,938 Posts
SOLVED --- I had this precise problem on my 99 recently. Solution is to buy a new overflow tank. It comes with the sensor installed/attached. The sensor is not sold separately from GM yet.
Of note, there are some large vendors here who have good prices... but I got mine direct from AC Delco via Amazon PLUS shipped it 3 day for less than the discount price elsewhere.
Alternative - connect the wires to themselves. Apparently, from searching the forums here, the indicator only lights up when the connection is broken. Connect them and you'll never have the signal pop up again.
Old 07-16-2013, 12:30 AM
f6john
f6john's Avatar
I get the low coolant warning from time to time on my 99. It always/only seems to happen when I am stopped in a somewhat nose down position, like the end of my driveway. Never had any temp problems so I have left it alone.
Old 07-16-2013, 08:53 AM
Oldvetter
Oldvetter's Avatar
I was going to mention this, this is one known "malfunction". I have had it happen to my 1998.
I am thankful that the Corvette has a low coolant level light and a low oil level light, all cars should have these important warning lights!
Old 07-16-2013, 12:25 PM
The Big Guy
The Big Guy's Avatar
St. Jude Donor '12-'13-'14
99 6mm Had the same problem with the low level. After much adjusting and fooling around, I finally found out that the level WAS actually LOW ! Added a small amount of fluid and have had no more problems. I know this sounds goofy, but it actually happened. Add some fluid and see what happens.
My 2 cts.
Old 07-17-2013, 09:21 AM
tycksena
tycksena's Avatar
I've had this problem with my '99 for a long time as well. It seemed to happen at the same stoplight everyday on my way in to work. It's definitely a "nose down" stop so I thought that or one of the sensors in the road messed with it. I always just cleared it because I knew I wasn't low on coolant. Recently the plastic T for the hose hookups on my surge tank cracked so I replace the surge tank with one from '97-'99 and it came with a new coolant sensor and sure enough it still goes off daily even though the coolant level is fine. I am seriously considering just wiring the terminals together to never get it again.
Old 07-17-2013, 10:20 AM
The Big Guy
For what it's worth, try adding a small amount of fluid, even though it reads full, and see if it solves the problem. It did in my case.
The Big Guy !
Old 07-22-2013, 06:09 AM
nyelectrify
I had replaced the coolant reservoir and found out that they gave me the wrong one. Problem solved. Turned out that from 97 for a few years they have sensor. After that they don't.
Old 07-22-2013, 04:01 PM
MG RED 99
MG RED 99's Avatar
There was also a technical service bulletin many years ago for the earlier model years that involved shimming the tank with washers. If I can find that old bulletin I'll try to repost it here.
Here's another forum link that discusses the low level issues as well. It's an old posting but may help.
http://forums.corvetteforum.com/c5-t...t-message.html
And another link to owners with the similiar problem
http://forums.corvetteforum.com/c5-t...urge-tank.html
Also just another FYI. Sludge can build up on the float inside the tank on the earlier models. Just removing the tank and rinsing with clean water and shaking it a bit may free up the float. Just something to try before anything else and it costs nothing.
Vette-Dream (06-12-2017)
To Reads low coolant level when not. Bad sensor??
Quick Reply: Reads low coolant level when not. Bad sensor??
