Which shifter is this?
The sticker says Breathless Performance Products. Although it may be unreadable. Try their website and you will find that shifter.
Here's a link to that shifter on thier website:
http://www.breathlessperformance.com...productId=1135
Just a FYI. See that wedge in between the shifter base and the shift lever? If you look at the bolts they are being pulled at an angle instead of being installed straight through the lever into the shifter. Due to this angle on the bolts, a few forum members have had the bolts break leaving them stranded when they couldn't shift the car. Personally, I'd take that wedge out if your shifter has it. I can't tell for sure but it looks like it's in there.
