Converting to regular tires
Old 06-12-2013, 11:33 PM
Caveboy
Caveboy's Avatar
Default Converting to regular tires
Is there any special procedures to convert my car from run flat to regular tires. Also, is there any advantages to that besides a lot more selections of tires?
Old 06-12-2013, 11:39 PM
feeder82
feeder82's Avatar
no just buy the new tires. better ride,quieter ride
Old 06-12-2013, 11:58 PM
Caveboy
Caveboy's Avatar
Any recommendation on tire size and brand. I have stock wheels and like to go a little bit wider
Old 06-13-2013, 12:18 AM
NukeC5
NukeC5's Avatar
advantages are weight reduction, wider variety of tires, and better performance tires, and much cheaper tires.
stock size are 245/45 17 and 275/40 18. When ditching the run-flats, i went with Nitto NTO5's in 255/40 17 and 285/35 18. Those are basically one size larger all around and fit perfect.
Old 06-13-2013, 01:35 AM
Caveboy
Caveboy's Avatar
If I go to a bigger tires, do I need to recalibre my speedometer and how?
Old 06-13-2013, 08:40 AM
jlaw1313@comcast.net
jlaw1313@comcast.net's Avatar
If you are going to transition to nonrunflat tires it would be prudent to purchase a tire repair kit and tire inflator.
It is important to maintain the stagger from front to rear or issues may arise with active handling.
Stock Sizing
Front wheels are 17" x 8.5" with +58mm offset and backspacing is 7". Total wheel width is 9.5".
Rear wheels are 18" x 9.5" with +65mm offset with and backspacing is 7.5". Total wheel width is 10.5".
245/ 45 -17 25.7" diameter *4.3" sidewall (Front-stock size)
275 /40 -18 26.7"diameter * 4.3" sidewall (Rear-stock size)
Stagger 1"
295/ 35 -17 26.1" *diameter *4.0" sidewall
255 /40-18 25.0"*diameter *4.1" *sidewall
Stagger 1.1"
255/45-17 26.1" *diameter *4.5" sidewall
285/40-18 27.0" *diameter *4.5" sidewall
Stagger .9"
255/40-17 25.0"*diameter *4.0" sidewall
285/35-18 25.9"*diameter * 3.9" sidewall
Stagger .9"
Little lower profile for looks and a touch wider.
But realize, not all brands have the same tread width...... e.g., a Bridgestone PP or a Kuhmo MX have significantly wider tread than, say, a Goodyear D3.
go to the tire rack and check out the specs.
I would not go much wider than a 285 on the rear tire, pushing the stock rim width size a little. Also watch the sidewall or profile height. You may not like too low or too tall of a profile or a different profile size from front to rear.
Here is a handy tire size calculator I think I picked up on Toque's website. The calculator will also give you the speedometer calibration of change if you decide it is worth having a tuner change the setting for you.
http://www.rimsntires.com/specs.jsp
Personally I went with Nitto Invo in stock sizing. Good Luck!
Old 06-13-2013, 09:55 AM
PNW Vett
PNW Vett's Avatar
St. Jude Donor '13
Good info jlaw.
Old 06-13-2013, 11:12 AM
GySgt1811
GySgt1811's Avatar
I did the same a couple of months ago. I kept every thing matched with the stock sizes, though. I put on a staggered set of Hankook V-12's and couldn't be happier; great ride, better traction, and sweet goodness, a much quieter ride. AND, at half the price.
There are so many good tires out there...I went with the Hankook's because of Forum recommendations, prior history with Hankooks on another car, and price.
Enjoy your new ride.
Gunny John
PS. I have a set of almost new Goodyear runcraps for sale.
Old 06-13-2013, 12:04 PM
coupeguy2001
coupeguy2001's Avatar
2021 C4 of the Year - Modified Finalist
I went with kumho tires. The runflats were getting really noisy, and when I went around corners, the car would slide because the rubber was getting hard.
With the new tires, the only noise I hear is when I am stopping, just almost stopped, the road noise is apparent.
Otherwise, they are pretty quiet. I went with the original sizes. In fact, I liked them so much, I put C5 wheels and these tires on my C4.
<----------------------nice upgrade.
Old 06-13-2013, 01:49 PM
derek502
derek502's Avatar
Gunny John
I agree 100% I bought the same tires a few months ago too..
Old 06-13-2013, 06:25 PM
c5vetteguy
c5vetteguy's Avatar
2018 C5 of Year Finalist
Originally Posted by NukeC5
...stock size are 245/45 17 and 275/40 18. When ditching the run-flats, i went with Nitto NTO5's in 255/40 17 and 285/35 18. Those are basically one size larger all around and fit perfect.
I don't know where you got your figures from, but both your front and rear tires are smaller in diameter than stock.
Old 06-13-2013, 08:31 PM
NukeC5
NukeC5's Avatar
Diameter yes, not width. These sizes are within the needed stagger difference between front and rear and do not cause any issues.
Old 06-14-2013, 09:35 AM
c5vetteguy
c5vetteguy's Avatar
Call me old-fashioned, but when most people want to go with larger tires, they want to fill out the wheel wells more (increasing diameter). A side benefit is that they usually get wider as a result. 99.9% of the views of your car is from the side. No one will notice a 2/5" increase in width, but they will notice a sizable decrease in diameter.
Nuke, can you show us a side shot of your car? I'm curious as to how much of a difference your tire setup makes.
Old 06-14-2013, 11:53 AM
NukeC5
NukeC5's Avatar
I am lowered on the stock suspension currently, and have a set of coilovers on the way as we speak actually. So I will be able to tuck the wheels nicely with the new setup. Ill see if i can find some shots from before though. It really makes no difference visually. I remember seeing that the diameter would be less, but upon holding the good-years and nittos side by side when I had them together, they were the same height.
Old 06-14-2013, 02:47 PM
rob-cyn
rob-cyn's Avatar
Is there any way to turn the tps system off ? I have C6 rims on my car and am tired of the constant check your gauges warning on the hud. It would be nice to make that go away.
Old 06-14-2013, 09:10 PM
c5vetteguy
c5vetteguy's Avatar
You can't do that via the C5's options, but I've heard that you can with a tuner. You should ask this question as a new thread and you'll get more knowledgeable responses. This question can easily be overlooked by those who know, if they don't read this unrelated thread.
Old 06-15-2013, 11:51 PM
Soul per4mance
Soul per4mance's Avatar
Best thing i fide was get rid of the runflats. Much better handling now.
Old 06-25-2013, 12:14 AM
MrRenoman
MrRenoman's Avatar
Default Hankook V12 EVO Review
I bought these tires in Feb. 2010. It's now June of 2013. I have nearly 22,000 miles on them. They are nearly down to the wear indicators with 3/32" left on all four tires. I'm a cautious driver at 59 years old and don't do burnouts or aggresive turns. The tires seem to perform well in all conditions except snow. I'm somewhat disappointed in the mileage but they are a performance tire. I bought them from PeP Boys mounted, balanced and alignment for $900. I received a $200rebate on their Buy 3 Get One Free program. I think I got about the best any one can expect from these tires. The price was right at the time I bought them. I'd buy them again. I went with the stock tire size 17" front, 18" rears.
Old 06-25-2013, 01:15 AM
dblerman
dblerman's Avatar
2001-2004 can have the TPMS turned off with a Tech II.
Honestly, the better option would be to just install working sensors.
To Converting to regular tires
Quick Reply: Converting to regular tires
