2000 Vette convertable has intermittent won't start problem
Old 08-05-2013, 07:34 PM
patrickdelahoussaye
patrickdelahoussaye's Avatar
Default 2000 Vette convertable has intermittent won't start problem
CALL ME FRUSTRATED:
SOME TIME BACK I WAS ON THE FORUM AND LISTED A NOTE THAT MY 2000 CORVETTE WOULDN'T START "EVERY ONCE IN AWHILE". AND YES THE LIGHTS COME ON WHEN YOU TURN ON THE KEY AND THEY DIM WHEN YOU TRY AND START THE CAR. HERE IS WHAT IT ACTS LIKE: "SIMPLY A LOOSE GROUND" NOT
CHECKED ALL CONNECTIONS ON THE BCM, BATTERY, ETC.
ANY HELP > HERE ARE THE CODES AS SEEN:
>PCM 1 CODE > P1631H
>AO-LDCM CODE> B2262H "unable to clear it"
> B2264H "unable to clear it"
IF THERE IS ANYONE THAT COULD HELP ME>PLEASE CHIME IN. >THANKS
Old 08-05-2013, 08:31 PM
c51stvette
c51stvette's Avatar
Suggest you read the Bill Curlee threads on the ignition switch
If you are comfortable with a voltmeter then do all of the suggested diagnostics. Your problem may be caused by something else.
I went through an intermittent start problem last year and I tried to give feedback to all who helped me. My problems were caused by bad contacts in the switch.
Do some searches and some reading, there are lots of good threads on this forum.
Old 08-05-2013, 08:47 PM
patrickdelahoussaye
____________________________________
ok THANKS
Old 08-05-2013, 11:25 PM
BigGun
BigGun's Avatar
>PCM 1 CODE > P1631H
Was the starter one of the connections you checked?
Old 08-06-2013, 06:02 AM
patrickdelahoussaye
Starter was replaced.
To 2000 Vette convertable has intermittent won't start problem
Quick Reply: 2000 Vette convertable has intermittent won't start problem
