Goodyear Gatorback Poly-V Serpentine Belts?
I can't seem to find any Goodyear Gatorback Poly-V Serpentine Belts for my 1997 Corvette. Everyone I've talked to says they have been discontinued...
I believe the part numbers to be 4060802 for the main drive, and 4040420 for the AC drive. Can someone point me to where I might be able to find some? Thanks.
that's not at all the case. i just ordered goodyear belts from amazon
rock auto also often has them
if for some insane reason you can't find them dayco also makes a poly belt with a similar non squeal material
How about the new Gates Racing serpentine belts? They're BLUE!!
Looked on gates site, only lists the AC belt in the "Racing belt"... Bit ironic seing how most race cars remove the AC
http://www.gatesracing.com/parts.aspx
A.C. High Performance Automotive V-Ribbed Belt K040420RB (Blue)
Serpentine - Accessory Drive Automotive V-Ribbed Belt (Standard) K060802
Advanced Construction
- High-modulus, low-stretch polyester tensile cord with the strength to transmit load more accurately with less vibration
- Advanced belt profile that is precision ground for an exact fit
- Strict adhesion to OEM dimension specifications, eradicating slip noise and accessory belt drive wear
Innovative Materials
- Specially engineered adhesion layer offering extended service life
- Durable overcord made from heat-resisting polyester fabric
- Undercord reinforced with heat-resistant and strong aramid fiber technology
Distinctive Appearance
- Signature style and customized look with an expanded product line and new color selections
The six rib main belt shows:
Serpentine - Accessory Drive High Performance Automotive V-Ribbed Belt K060798RB (Blue)
