P1870 transmission code
Hey guys, I have a 2003 C5 that has a P1870 code. It has a factory automatic Trasmisison and I have replaced the Torque converter and the Valve body at my local chevy dealership with no luck. They tell me that the rear diffential has been changed from the stock 2.73 to a 3.42 and thats the issue. Any thoughts you might have? This is driving me crazy!!!!!
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
See post #2. Any tuner can do this for you. If the diff was swapped to 3.42 there are other things that need to be changed like shift points, line pressure, how the torque converter works, ect. The dealer may have flashed a stock tune in the car when they did some of the work you mentioned. A performance shop or vette specialist would know this.
P1870 Code
