Oil pressure
Old 11-10-2013, 02:40 PM
Lafittez
Lafittez's Avatar
Default Oil pressure
Just installed my new motor ls2 built motor. Iv had no problems with it till one day i got into the car and all of a sudden the oil pressure started to read a little lower then normal. I checked the oil level and there was no problem there. gradually day after day once the car warms up the pressure is sitting at 15 psi. At startup its at 45 psi using 20w50 breakin oil. after a few minutes idling it starts to fall off. The engine sounds fine. and it drives fine. Do you think it would be a bad sensor? while at 15 psi if i just barely touch the throttle it jumps to 35 psi. cruising its sits in the 40 to 45 range. 190 degree engine water temps
Old 11-10-2013, 06:27 PM
Silverbullet00
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Try 5W30 and see what happens!
Old 11-10-2013, 08:32 PM
Lafittez
Lafittez's Avatar
That's my next move. I believe the oil pressure sensor is easy to get to so I may change that just in case.
Old 11-11-2013, 12:42 AM
a/c man
a/c man's Avatar
My Ls2 gets down to 20psi too I think these built motors have more clearance. Let us know how the thinner oil does I run 20/50..
Old 11-11-2013, 04:27 AM
Lafittez
Lafittez's Avatar
Hmmmmmm that's odd. Glad I'm not the only one in this boat. Going bring it to the tuner today. I'm going to let him check it out before I go wasting money on another oil change.
Lafittez
Lafittez's Avatar
Will keep you posted tho
Old 11-12-2013, 07:55 PM
Lafittez
Lafittez's Avatar
Motor builder said that pressure is just not right. He suggested I check the oil pickup tube and oring the oring is known to fail.
Old 11-12-2013, 08:21 PM
a/c man
a/c man's Avatar
been there too. that lots of work to pull the pan.
do you always have low pressure or just at a hot idle. Mine is only when my oil gets above 230* so Im adding a cooler check this thread out!
http://forums.corvetteforum.com/c5-f...-and-cons.html
Old 11-12-2013, 08:25 PM
a/c man
a/c man's Avatar
When you change your oil cut the filter open with a knife and look for metal dust in the filter media that will tell you if your bearings are the problem.
Old 11-12-2013, 08:33 PM
renegade123
renegade123's Avatar
Some thing is loose probably...a thicker oil should cause higher oil pressure , any air bubbles on you're dip stick ?
Old 11-12-2013, 08:58 PM
Lafittez
Lafittez's Avatar
Heyyyyyy you know what I did notice some small bubbles on the dip stick!!!!! I thought it looked odd but didn't think nothing of it at the time!
To Oil pressure
Quick Reply: Oil pressure
