Leak Into BPMV
Leak Into BPMV
I found a leak into the BPMV on my 2000 C5 FRC. There is some sort of pressure relief device? between one of the lines from the proportioning valve and the BPMV. Spent the day at the GM dealer, he tried to locate the part, but none of the parts schematics show it! Tried to show it with the red oval in the pic attached. If anyone has any idea where to find one of these, I would appreciate it. For now, there is a small hole to the outside, I plugged it with a large piece of wire and JB Weld (not the best approach I know).
Bill Curlee, if you have any ideas?
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WELL,,,,,,,,,, That is NOT an OEM part. The OEM line should be connected directly to the BPMV block.
Looks like its some sort of aftermarket proportioning valve
Do you have any aftermarket calipers or changes to the rear or front brake system??
Bought the car new, have not added anything t that area of the brake system and never had any work done on the brake system by anyone other than myself! Tried to bypass the part by connecting the line directly to the BPMV, but could not get it to reach! The part has an internal portion, sort of a bypass short line with two holes in it on opposite sides about 1/2 inch apart. There is a rubber diaphragm inside the block portion and it has two O-Rings, one on each side. It HAD to come from GM this way. Looking for a new line about an inch and a half longer on the BPMV side to just do away with it!
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hmmmmmmmm,,, Ive never noticed or seen anything like that before on a C5. What year C5 do you have???? I will look in that year mechanical diagrams.
Bill
Bill
It is a 2000 FRC, bought in November 1999 from a local Chevy dealer in California, as I understand it, the FRC came standard with a lot of the "performance" parts such as the axle ratio, stiffer springs, larger anti sway bars etc. could post the RPOs if that would help.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Contact Marc at VETTENUTS (C5/C6 SALVAGE YARD) and see if he has a good used one.. Still don't know what it is exactly.
BC
BC
