'98-'02 Exhaust Compatibility
I'm looking to pull the ARH's off my '02 A4 and put the exhaust back to stock. I have an offer to procure the exhaust manifolds from a '98. The exhaust manifolds for the '98 are the SS sheet metal and the H-pipe has a different part number than the '02. Anyone know if the '98 manifolds and h-pipe will fit an '02 as a set? I've never tried a cross-fit exercise on these. I guess the AIR and dip stick mount setups would need to be modified on the passenger side.
Agree, the manifolds and H-pipe will both need to go on. the AIR pipes are different and the Oil Dip stick are different.. so its not really a straight swap... but it can work... be best if you found another 00+ car to swap from.
