Belt/alternator squeek is driving me crazy.
I've been trying to cure a intermittent belt squeak ever since I bought my 04 Z06. I've replaced the main drive tensioner and pulley, both belts, the a/c tensioner and idler, even thought I had a leaky water pump causing it, replaced gaskets and still get the squeek. When cold its the worst when hot it only does it with a quick throttle blip. I'm honestly starting to think its the alternator. I can remove the belt and spin it and hear the slightest chirp noise. It sounds exactly like the belt squeak I'm hearing. Has anybody else had a problem like this that turned out to be the alternator? I'm clueless and noises like this kill me. Thanks
I and many others have had that exact story. Even after changing belts, it still turned out to be the main belt making the noise. Get a Gatorback main belt and I almost guarantee it will fix the problem.
The noise I believe is coming from the teeth on the belt rubbing the valleys on the pulleys. The gatorbacks have short teeth that do not contact the pulley valleys. Worked for me anyways.
1 Post
Just completely remove the belt, then start the engine to see if it the noise is gone. Running your engine a few minutes without the belt won't hurt anything. This will help you isolate the noise....hopefully. I r/r's my belts with Gatorbacks and have never had a noise.....however, I never had any noises before either and changed them at 50K miles as a preventive measure.
Good luck!
Good luck!
Just pulled the main drive belt and left the a/c in tact. Noise is gone with main belt removed so thats definately where my problem lies. Where can you get the Good year gatorback belts now. Autozone says they don't carry them. The belts on it are gates.
1 Post
Good luck
1 Post
Is AutoZone the only parts store in your town? I like to buy local so I can look those guys in the eye, and no waiting a week for a UPS box. Google is always my first step in researching parts. Too many rip-off artists out there peddling "Corvette" parts, when most are available locally anyway if a guy just pays attention. Good luck
I saw that so many of you had success with the Goodyear Gatorback belts that I got one (the main belt; stock # ends in 798) and put it on my 2001 5.7L. THE NOISE IS GONE; HOWEVER---- While replacing the belt, I noticed that as I would release and apply the belt tension on the main tensioner pulley (top of engine, passenger side), that the pulley would turn slightly sideways. (Tension off, the pulley would be straight; tension on, the pulley would go slightly sideways again.) Even though the new belt eliminated the squeak/squeal, I am convinced that the pulley was the main problem and I did not want a pulley out of line. I have just replaced the tensioner/pulley ($40 for the part). It took me less than 10 minutes to get the belt off, unscrew the two tensioner/pulley bolts and remove, and replace with the new tensioner. I've got a total of $60 in the belt and tensioner/pulley.
Belts/Bearings Squeal
Vette Folks,
Just want to post my 2 cents on this. I have a an 03 Z06 that had an intermittent squeal especially after high moisture exposure like rain or heavy dew. Noise started at about 110k miles. Last week at about 127k miles it became constant and very annoying. After reading the forum info I could find (which was plenty but nothing conclusive), I dropped by Autozone and bought both belts, both tensioners and both idler pulleys to a tune of $192. It was the right thing to do to replace all of that. The noise turned out to be either the AC belt tensioner or idler (verified by cranking the engine with main drive belt off for about 5 seconds). But most important is what I am about to say. I spun both removed tensioners and both idlers and they all spun 'free-wheeling' as if they were dry and 'slap worn out' (which they were). They should not do that if properly lubricated. I got to thinking why this was so. It is purely mathematical, so to speak. The idlers and tensioner pulleys are roughly 1/4 to 1/5 the diameter of the crank pulley. 1 million revolutions on the engine is about 4-5 million on each one of the smaller pulleys. I know you guys never push you engines up to 6k RPM, but if you did those same smaller pulleys are doing 24-30k RPM. Quite simply they will wear out! This really goes for the alternator bearings also since it also has a smaller pulley. Hope this helps some folks.
Get in, crank it up, and drive it like you stole it!
