2003 C5 6 speed
2003 C5 6 speed
I am having trouble shifting from 4th to 5th gear. I thought I was going past 6 to reverse because I was getting some gear clash. I have been told three things: 1. It could be the reverse lockout solenoid is not getting power. 2. The spring that is part of the reverse lockout may be bad. 3. It may not be reverse I am hitting and it may be the syncro for 5th gear and it is really the 5th gear that is clashing. If anyone has run into this and has some solutions it would be greatly appreciated. Thanks, JHDill 12-24-2013
My '04 is an automatic but before that I had a '98 coupe , 6 speed ,and I ran into the EXACT condition. I thought it was something that I was doing , and all of what you are thinking. After some research , it seemed more and more like a shifter alignment issue so I went through the procedure of aligning the shifter and it shifted perfectly after that. Check this video.
Hope it helps!
Hope it helps!
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The very first thing that I would is change out the thansmission fluid. I would replace the DINO ATF with some new fresh AMSOIL Torque Drive ATF! Any new ATF will do but, you have the ability to up-grade to a good synthetic ATF. It takes 4 quarts. All you will be able to remove and replace is 3.75 qts.
Its a simple solution and if you dont have any actual mechanical damage, it may very well solve your issue. I had some minor gear clash when shifting from 4th to 5th in my 98 C5 Coupe.. Just changing the NASTY ATF, resolved the issue. Hell,, its a very inexpensive possible solution. Give it a try.
IF,,,,,,,,, you have any actual mechanical damage inside the trans, the fluid change will not resolve the issue.
Bill
Bill
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Speaking of SHIFTER ADJUSTMENTS,, carefully examine the two rubber bushings that isolates the shifter from the torque tube. If they are seriously deteoriated and soft, they can and will cause shifter / shifting issues.
One of the Forum Vendoes sells a up-graded nylon replacement bushing that makes the shift feel a LOT better.
The shifter in the picture below is a C5 ZO6 shifter. Its the same as your OEM Stock shifter (EXCEPT) the C5ZO6 shifter is mounted with SOLID Aluminum bushings. Yours are rubber:
Bill
Bill
Bill
Bill
2003 C5 6 speed.
Hope it helps!
Corvette shifter adjustment video by froggy - YouTube
Hope it helps!
Jim
Bill
Bill
I had this problem on my 2003 six speed as well, and the only solution was replacing the reverse lockout solenoid. 5th gear and reverse are really very close together, without that solenoid it is FAR too simple to hit R instead of 5.
Actually changing out the solenoid was amazingly easy, though. There's only 1 bolt you have to remove, and then the solenoid and the bracket it attaches to both come off the trans. Take that to your workbench to remove the solenoid from the bracket it's attached to, replace with your new solenoid (which will be of a slightly different and hopefully better design, as well) and replace. No fluid loss in this process either.
I *highly* recommend if you already are planning on putting the car in the air to change the fluid, you replace the solenoid as well. I paid $64.43 for mine after taxes and shipping from Amazon.
This thread describes the process: http://ls1tech.com/forums/manual-tra...-solenoid.html
Thanks for the tip. I got the top about looking at the solenoid from MGW when I looked at their replacement shifter. I spoke to the person who designed the MGW told me it sounded like the reverse lockout solenoid was bad. He said I should not be able to hit reverse if the lockout is working properly. I think I will get the MGW shifter after I check out all the tips I am getting.
Thanks for you insight. Jim
I am thinking that I read that it is possible to overcome the reverse lockout if you push hard enough, so that you can still get the car into reverse if the solenoid fails. I had the problem of over shifting into 5th with my spring loaded Hurst, but the problem went away when I changed to a shifter that did not have the extra loading.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES.... It takes approx 25 lbs of force to push past the lock out gate.
I had the same problem earlier this year. I could upshift from 4th to 5th to 6th, but couldn't downshift from 6th to 5th. Had to double clutch or shift from 6th to 4th and back up to 5th.
However as mysteriously as the problem started, it also went away without explanation. It's fine now. ???
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IF ,, It were me,,, an it wasnt ever done, I would change the trans ATF fluid.. You will be surprised at the difference it makes in shift quality.
Premium Supporting Vendor
If you do decide to try the AMSOIL Torque-Drive Synthetic Automatic Transmission Fluid (Product Code ATD1G) (same fluid I use in my 02 Z06 at the track), more than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
My big problem is I don't have anyway to change it myself. I am looking for someone I can use in my area to do work besides the dealer. Thanks for the tip I will be sure to use your suggestion if I find someone. If anyone knows someone that services Corvettes in the Lake Wales, FL, please let me know. Thanks again, Jim
I do think the fluid change is a simple and relatively inexpensive first step.
I have the same problem right now. and with the help on the forum I have changed things. for mine it was grinding going into second and I bought new shifter bushing and then the problem moved to third and fourth gear. so I will align the shifter and see that. there is plenty of help on the forum and these guys right here are very helpful. keep us updated.
