Rear cover bolt torque
What's the torque for the eng rear cover bolts?
Should the rear main seal (inner surface) be installed wet or dry? I've seen both methods recommended.
Rear cover
Reviving a thread from the past.
Is it ok to install the rear cover without sealing the cover surface w RTV or any sealant?
I have a minor oil leak after installing the rear cover w crank seal and after doing a clutch. Im hoping its something else
I have a similar issue, did you find out what the solution was?
I did, but I didn’t use high temp RTV. I currently have a leak and in the process of pull the drivetrain again 😅. Also, I torqued all the rear main cover bolts.
i was hoping the leak was coming from the oil sender/sensor but I don’t think it the case sadly.
https://www.z06vette.no/2023/08/new-...ine-seals.html
