98 C5 A/c & Heat prob
Old 01-26-2014, 02:01 PM
triziks
triziks's Avatar
Default 98 C5 A/c & Heat prob
I started my car up the other day and cut on the AC and it all works i can hear working properly but nothing blows out the vents. I then tried turning my car off and on to see if that would fix the problem and nothing. I can hear it working when I switch on the AC or the Heat and different settings but still blows nothing. It has happened to me before and 1 day I just got back into my car and it all worked fine. Can anyone help me?
Old 01-26-2014, 09:46 PM
ez2spd
Support Corvetteforum!
ez2spd's Avatar
Have you done any work under the hood? There is a vacuum behind the manifold that can cause a mess or problems with the HVAC, also check DIC for any HVAC codes... Is the compressor kicking in when you turn it on also?
Quick Reply: 98 C5 A/c & Heat prob
