buying a aftermarket clutch.should I go with a lightweight flywheel
St. Jude Donor '14
Im about to start updating my transmission and clutch and im looking at the monster stage3 clutch.
Its giving me the option to choose between a 18lb light weight flywheel or a 28lb billet flywheel.
Which one is good for mainly dragraceing and for a car that has a big cam?
On the other site people are saying that a lightweight flywheel hurts performance from a dig and a heavy fly wheel would be better from a dig and if you have a big cam installed.is this true?
Here is the clutch im looking at
http://www.monsterclutches.com/shop/...5-package.html
Lightweight ones are more for road racing. The more stout billet one is more suited for drag racing. Cutting hard 60s are murder on aluminum flys.
St. Jude Donor '14
St. Jude Donor '14
Argh too many mixed reviews..drag racers swear a heavy flywheel is the way to go but there's plenty of articles debunking the myth of a heavier flywheel is necessary for drag racing.
I think Im just going to take a chance and go with a the heavier flywheel over the lightweight.
heavier is easier to launch and some say easier in parking lots. it's absolutely better if you're using a stage3 or higher clutch
with organic or kevlar you could go either way. personally i like lighter flywheels and both of these flywheels are billet steel. the weights you posted made obvious which company it is
if you rev match going into corners, autocross or generally like a lively car get the lighter one
if you do more drag racing or lugging around parking lots get the heavier one
St. Jude Donor '14
I do more drag raceing than anything..I dont autocross or anything like that since we dont really have those facilities out here where I live..
I dont drag race alot, mainly a few empty street runs every now and again..its my Daily driver.
St. Jude Donor '14
If anyone has any other recommendations for a clutch and fly wheel combo for under $900 other than the one I posted plz pm or let me know. .
I know I need something that can handle atleast 650-750rwhp since ill be adding a supercharger in the summer..
Im trying to get the tranny and clutch work done before I add the supercharger.
The heavier flywheel will likely make the car a little slower at the strip but for daily driving it's a no-brainer.
Have you looked at the ECS Mantic ER2 clutch? It appears to be dual friction (organic on one side and ceramic on the other) so it might engage smoother then the Monster clutch. They've just never posted much detail on that clutch has besides the grooves being so wonderful.
There are single disk clutches that will hold your power but they are going to pretty stiff and hard to press. I previously used single disk clutches but this last time I went with a Mcleod RST dual disk and it was so much lighter. The dual discs are more expensive but worth it imo.
1 Post
The Monster clutch "lightweight" flywheel is still billet steel and at 18lbs it's about 4lbs heavier than an aluminum flywheel from Fidanza. Also keep in mind that the Monster pressure plate weighs more than stock so the total package with the lightweight flywheel is not much less than stock.
In this link, someone weighed their Monster stage 3 clutch & pressure plate with the 18lb flywheel and it came to 46lbs complete. They said their stock ls1 clutch, pressure plate, and flywheel came to 49lbs. http://ls1tech.com/forums/manual-tra...ight-info.html.
Heavier is faster at strip.period., the heavier the flywheel acts as stored inertia and help launch car. Now if you have an auto only way to take advantage is higher stall converter and a tranny brake. Stick car just dumps clutch of course. Stickier tire next. All your gains in drag racing come in the first 60 ft, regardless of how light that alum flywheel lets the motor rev. Road racing different story, car is already moving. Lighter the better.
The article I linked had 2 cars go faster with lighter flywheels. It seems your claim is wrong...
You can launch at a higher RPM and get the energy back. You did know the energy stored is proportional to RPM squared so doubling the RPM will store 4X the energy if using the same flywheel? Dump some weight from the flywheel and you may only have to increase launch rpm by 500rpm to 1000rpm to get the same launch.
Actually what that is saying only applies if you are leaving at an idle with the heavier flywheel. If you noticed I said use the stored inertia by launching at high rpm by the use of higher stall and tranny brake. It's simple math really, a heavier rotating mass released at say 5000rpm propels the car forward more than a lighter mass at same rpm. Trust me I been drag racing for over 26 years and built just about every class of drag car from street to pro mod and alcohol funny cars. Car always ET faster when stored inertia is planned. The trick is trying to use this without blowing the tires off. More gains in tires prob than alum vs steel flywheel.
you can technify it however you wish but my experience has been that heavier flywheels are easier to cut a good 60ft with
LOL, I didn't "technify" anything, I posted the results of real world testing. The lighter flywheels picked up over a 10th of a second in 2 different cars.
Claiming heavier is faster "Period" is ridiculous when it's like a lot of other things - it depends.
St. Jude Donor '14
ive been looking at the Mcleod RST dual disk but they i dont see any packages where as the clutch,flywheel and pressure plate..do i order these separate?
This real world testing is always based on a number of factors, but if drag racing is your goal, the 60 fts are your friend. Now if street racing the lighter flywheel is my choice only cause you may already be moving. If your trying to say its conclusive that lighter is better at the strip then maybe you should go to the track and ask around. All the prostock or comp eliminator guys will be happy to explain their 30 plus years on this subject.
