Kip Fabre @ Cam Motion
I spent around 4 months chasing a whining noise in my car. I was 99.9% certain it was the camshaft, because it started happening right after I swapped cams, even with the belts off. I even tried another cam from the same vendor and it still whined. Many other people were reporting the same noise as well, but we were getting no answers and not much help.
Kip found our thread and chimed in with his expertise and told us he was just about 100% certain it was an issue with the cams not being polished properly. He offered to polish our cores for free and send them back to try. However, since I was already fed up with swapping cams twice, I didn't want to take any risks, so I elected to buy a brand new cam from Cam Motion instead. Kip sent me a new cam at a discounted rate and had the cam ground and polished the same day I ordered it. It was on my door step 3 days later.
I put in the new cam and the whining was GONE. FINALLY. Thanks Kip @ Cam Motion! The only guy who knew what was going on.
Cam Motion is the only vendor I will be using for camshafts from now on.
Reference thread.
http://ls1tech.com/forums/generation...-change-8.html
Reference thread.
I went thru the thread...yikes! Your detail & attention is another yikes Nicely done & good on you for giving props
I'm currently considering a cam change & this will influence that for sure
Don't hesitate to go with them, you get what you pay for and this is not a swap I ever want to have to do 3 times to get right again.
