Sticking Clutch Pedal
Old 02-27-2014, 01:28 PM
Cee5Go
Cee5Go's Avatar
Default Sticking Clutch Pedal
Had the clutch upgrade done about 3 months ago on my 1999 C5 with 75,XXX. Every so often clutch sticks to the floor like it did before the clutch upgrade was done due to a leaking clutch slave. I went with a OEM ZO6 LS7 clutch kit and LS7 flywheel. Also the slave cylinder was the LS6 upgraded slave. Everything was changed except the clutch master cylinder. Could this be my problem for the pedal sticking to the floor sometimes?
Old 02-27-2014, 01:30 PM
Stickyc5
Stickyc5's Avatar
This is a big a problem a lot of people had to deal with while high RPM shifting. Get a Tick M/C and your problems should go away.
Old 02-27-2014, 01:36 PM
dagon138
dagon138's Avatar
New Master cylinder for sure! Might I suggest you get the OEM one or the Tick (which I have) but get the special order one that has pedal engagement feel close to stock. I don't remember the diameter but they'll know what you are talking about.
Old 02-27-2014, 04:33 PM
TastyBacon
TastyBacon's Avatar
I believe the stock master is a 3/4" bore and the standard Tick uses a 7/8" bore Tilton. From what dagon138 is saying, it sounds like Tick can also do a 3/4" bore Tilton if you ask.
I agree that a new master cylinder should fix you up. If you look down by the pedals you may be able to see if yours is leaking fluid past the pushrod seal, dripping down the firewall into the carpet. That's how mine was.
Old 02-27-2014, 07:13 PM
PRE-Z06
PRE-Z06's Avatar
Received 2,054 Likes on 1,306 Posts
Have you tried bleeding it first to see if that helps? Hopefully you installed a remote bleeder along with the replacement clutch to make this easier, I assume you're not loosing fluid...report back on what you find.
Old 02-27-2014, 07:26 PM
COSPEED
COSPEED's Avatar
St. Jude Donor '10
I would skip the tick master and just get a new Gm one.
To Sticking Clutch Pedal
Quick Reply: Sticking Clutch Pedal
