What head gaskets for 243 head swap on 98 ls1
I know this May have been asked times before but I can't figure out because of conflicting answers.
So I need to know which head gaskets to use on a 98 stock ls1 Vette motor, putting on a set of 2002 243 heads do I use the gaskets for the ls6 or the ls1 ??? Keeping in mind the years of the two different parts.
Thx
Thx
Thx
Thx
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! They are your BEST bet!
Contact Gene or Patrick at gmpartshouse.com and get ya a set!
Ive used many an aftermarket set and NONE beat the GM MLS OEM Gaskets...
Bill
Bill
As mentioned, the 2002+ LS1/LS6 MLS gaskets will be correct. The older LS1 heads have a notch that requires the composite gasket to seal the coolant passage.
I would use a .040 Cometic gasket to bump the CR by .3 if your planning on a camshaft.
Russ Kemp
Russ Kemp
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT ADVICE! They cost more BUT,,,,, the added compression, makes POWER
Russ Kemp
