Pulled my codes. What do they mean?
Old 03-23-2014, 04:29 PM
Breeze51
Cruising
Breeze51's Avatar
Default Pulled my codes. What do they mean?
Hi guys. My first tech post , so here goes. My check engine light, active handling light and ABS light all came on the other day after the car had sat for about a week. I looked up how to pull the codes on this forum and here's what I got.
10-PCM PO135 H
PO155 H
PO161 H
P1571 H
P1689 H
28-TCS No Comm
40-BCM B0432 H C
58-SDM U1040 HC
60-IPC U1040 H
80- No radio codes
99 HVAC No Comm
AO-LDCM B2264 H
A1- RDCM No codes
A6-SCM No codes
BO-RFA C2105 H
I would appreciate any help deciphering these codes. Hopefully not a major issue. I've only had the car a couple months and love it so far. Oh, it's a 02 Coupe. Thanks again for your help.
Old 03-23-2014, 07:18 PM
c31980
c31980's Avatar
try this :http://www.stengel.net/diccodes.htm
Old 03-24-2014, 09:53 AM
dadaroo
dadaroo's Avatar
Make sure you charge the battery. Clear your codes and then see if anything comes back. You may have a drain dropping the battery voltage. Low voltage will throw a ton of codes even if the car starts. Suggest you use a voltmeter to monitor the actual battery voltage at the battery over a few days/week to see how it is holding up. Let us know how it goes.
Did the car run ok with the codes?
Old 03-24-2014, 01:20 PM
Breeze51
Cruising
Breeze51's Avatar
Yes, the car runs fine. I'll give the battery a good charge and go from there. Thanks again.
To Pulled my codes. What do they mean?
Quick Reply: Pulled my codes. What do they mean?
