Headlight stuck
Headlight stuck
I have a 1999 today i turn the lights off and the passenger light stay up but the light is off. if i turn the lights on the light lights but just doesnt retract when turned off. Where do i start to look for the problem .
Here is a link and you can see if this helps.
http://forums.corvetteforum.com/c5-g...orialized.html
But I would check fuses first if you haven't already
I went out to check the stops and the fuses turned car on worked the lights and now they are working maybe the drive gear in the motor is starting to go maybe
