Lowest Dust Pads
Lowest Dust Pads
I read some older threads but I'm wondering if there are current offerings that are even better.
What is the absolute lowest dust pad available? Car is not a track car, just an occasional spirited driver. It's a 98 Pace Car so the dust + yellow wheels is beyond annoying. The original pads are finally starting to squeak at 95k miles. The fronts are still factory but I'm going to swap all of them. The part that blows my mind is with the amount of dust the factory pads produce even on a short drive it makes no sense there is any pad left to speak of.
Supporting Vendor
St. Jude Donor '11,'13
Give me a call or go direct to our website. We will get you set up. The 1521's will solve your problems.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Received 1,673 Likes
I experience low dust with Raybestos Quiet Stops.
Supporting Vendor
http://www.ampdautosport.com/servlet...%29/Categories
F $140 R $121
The material is what determines how well the brakes bite, and in turn, how much they will dust. For example, a good ceramic pad will theoretically offer less braking potential as say a semi-metallic, carbon, or Kevlar etc. type pad, but will dust much less because it has less a intense bite. The performance minded will usually be using a pad unconcerned about dusting, but most of us in our street machines shouldn't need anything crazy. Id go with ceramic pads. They should last longer as well as keep the mess down.
The Raybestos quiet stops are a ceramic pad. And they have been discontinued because they were simply a basic ceramic pad with a lot of marketing behind them. A normal set of Raybestos ceramics will function exactly the same.
