HID's not working
Old 04-29-2014, 02:26 PM
Irony
Irony's Avatar
Default HID's not working
I have high/low/fog 6000K 35w HIDs with LED Taillights with Hyperflash Harness on a '01 C5. I don't drive much.
However the last time I drove @ night the lights started flickering and the driver side low went dead. I purchased a replacement and install and the HID bulb did not work. So I move the "new" HID bulb to passenger side and it didn't work as well. I reinstalled the working HID bulb on passenger side and now that and all HIDs high & low on both sides are not working.
The HID Fogs work fine.
I removed the all high/low HIDs and replaced with the standard 9005 & 9006 bulbs and they work fine.
What would cause my HIDs to fail.
HELP !!!
Old 04-29-2014, 04:36 PM
chris308
chris308's Avatar
ballast
Old 04-29-2014, 04:39 PM
Irony
Irony's Avatar
I could consider that the ballast would go on the 1st and maybe my 2nd troubleshooting of the bulbs....but all 4 ballasts???
Old 04-29-2014, 04:48 PM
Chicago1
Chicago1's Avatar
I'm sure you did but you did check the fuse? You can also test them on your fogs since you know those are working...
Old 04-29-2014, 04:56 PM
Irony
Irony's Avatar
Yup..fuses are OK
Old 04-29-2014, 05:02 PM
Chicago1
Chicago1's Avatar
swap them with your fogs then you will know if it's the ballast or not
Old 04-29-2014, 06:07 PM
pbfrench
pbfrench's Avatar
Had my HID fogs quit working, turned out to be the relay......
Old 04-29-2014, 09:10 PM
Irony
Irony's Avatar
If it's the relay wouldn't the regular bulbs also not work?
Old 05-07-2014, 12:39 PM
Irony
Irony's Avatar
bump for any responses
Old 05-07-2014, 09:46 PM
Chicago1
Chicago1's Avatar
Did you swap them like I suggested?
Old 05-07-2014, 11:52 PM
alxltd1
alxltd1's Avatar
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Did you install a dedicated relay harness for the HID's? Assuming you did, and you plugged the 9005/9006 bulbs into the OEM connectors they would not be going through the dedicated relay harness.
To HID's not working
Quick Reply: HID's not working
