ZR1 transmission ratios
I currently have a mildly upgraded T56 behind a Procharged 427. All is good other than the high 5th and 6th gear ratios. I'd really like a ZR1 TR6060, but I'm not anxious to put out $8K plus. Is there a less expensive way to get around a .85 5th and .65 6th gear ratio?
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
We have built TR6060 (both 2.66 and 2.97) with .80/.63 overdrives for some C5 owners. We can build you a ZR1 ratio TR6060 for a bolt in set up to your C5. Give us a call if your interested. BTW, it's cheaper than you think.
