LCM5 column lock message after install
I installed the LCM5 bypass unit under the passenger side, and it has been over a month, I still get the message, although the unit works perfectly and I did pull the relay. Can I get the code deleted so it doesnt register or come up again? I am tired of seeing this error come up
Navigator
Had the same problem with mine. Probably from it being a Canadian spec car. Anyway, after dealing with Compliance Parts I ended up with the 5 wire version of the LMC5 and that did the trick.
