Heavy Duty Pushrods and Morel/LS7 lifters on sale!!!
We have any LS lifter you need for your next cam install. But let's face it, most vette guys want more than an LS7 lifter in their setup right? Well we do have the LS7s on this sale also, but the MOREL DROP INS are THE GO TO lifter right now! Lower cost, drops right in, no worry on whether the tie bar faces in or out or if your pushrod is even IN the lifter!
THE MORELS!
The Morel Drop in Style 5315 lifter at $169 shipped.
The LS7 lifter sets will be $90 shipped in the lower 48.
EMAIL OR PM FOR PURCHASE INFO
The LS7 lifters are GUARANTEED DELPHI LIFTERS.
Anti-varnish design minimizes sensitivity to accumulation of dirt, gum and varnish
Chrome alloy ball check valve provides more precise valve opening and closing events
Hardened steel body and plunger minimize wear for life-of-engine service
Low-friction roller bearing helps maximize fuel economy
Roller surface is optimized to minimize the cost of cam lobe processing without loss of performance
Oil metering provides lubrication to push rod interfaces and other valve train components
Optimized dynamic performance design enables better control of the valve event at all engine speeds
Optimized to minimize occurrence of cold start noise with adequate oil supply
Typical Applications
Chevrolet Performance Roller Hydraulic Valve Lifters are designed for all cam-in-block internal combustion engines. Two lengths are available to meet customer requirements for mass and packaging.
Performance Specifications (for both configurations)
Maximum engine operating speed 6,000+ rpm (typical)
Roller follower material High alloy bearing steel
Roller follower crown radius 585 mm
Roller follower diameter 17.775 mm
Recommended maximum Hertzian contact stress 1,900 MPa with steel cam
1,650 MPa with austempered ductile iron cam
1,550 MPa with nodular iron cam
Oil supply pressure 100-500 kPa (typical)
Body outside diameter 21.4 mm (standard)
Recommended RHVL bore diameter
Cast iron: 21.425 mm to 21.445 mm
Aluminum: 21.417 mm to 21.438 mm
Set of 16 lifters for LS-Series engines
Same lifter used in LS2 and LS7 P/N 17122490 (single lifter)
Best prices around? YOU BET!
BUT WAIT! THERE'S MORE!!
We also have 7.400 5/16" chrome moly pushrods available for $80 shipped. .080 wall one piece sets of 16!
AGAIN PLEASE EMAIL OR PM FOR PURCHASE INFO
We do have ALL morel lifters on sale and quite a few other deals.
Let us know if we can fix you up on your next build!
THE MORELS!
Isnt that Morel a Small Block Chevy lifter? Looking on there website, the LS lifter is this one. http://johncalliesinc.com/product.php?ProductNo=4708
