LCM5 Installed - Just Started Receiving "Service Column Lock"
Old 06-06-2014, 10:32 PM
Macleod52
Macleod52's Avatar
Default LCM5 Installed - Just Started Receiving "Service Column Lock"
I installed the LCM5 last fall after I replaced my battery with a Red Top. Just today I started getting the Service Column Lock at every startup. My steering column does not lock but I though this mod would prevent the Service Column Lock message from appearing.
Has anyone else ran into this issue? Do I need the "Modified" version due to a finicky BCM?
Old 06-06-2014, 11:11 PM
Macleod52
Macleod52's Avatar
Will do. Thanks. Should I worry about driving her in the meantime? I don't want to get stranded.
Old 06-07-2014, 08:05 AM
dadaroo
dadaroo's Avatar
It will not lock on you because you have the lock motor disconnected by installing the LMC5. They just need to work with you so the BCM does not throw any messages.
To LCM5 Installed - Just Started Receiving "Service Column Lock"
Quick Reply: LCM5 Installed - Just Started Receiving "Service Column Lock"
