Help................... Shifter issue......anyone
OK now that i have more questions the key has to be in the on position and the brake pedal has to be pressed and the button on shifter has to be pressed to move the shifter from park or to be put back on park . now once out of park the shifter slides back and forth car does not start at all car seems to be in neutral looked under the vehicle but seems you have to drop exhaust to remove trans protection plate to get to trans cable. any help is needed guys...............................HELPP PPPPPPPPPPPPPPPPPPPPLEASE: smash::***** ::f lag:
ok done found the problem the shifter cable linkage that hooks up to shifter linkage was worn out broken so after removing exhaust,, tunnel plate i got to the shifter linkage the connector was broken at the shifter side so i went to Orileys and bought a Help product a shifter linkage repair kit $5.00 and made some adjusting so that it would lock on and after 2 1/2hours vette was back on road easy fix. thanks even feels better when shifting no play ....................lesson fix it yourself and learn something.
