Reverse gear???
Reverse gear???
What end of the trans do you disassemble to get to the reverse gear?? I have to fix my reverse gear popping out and grinding and now will not engage at all. 1999 c5 6mn.
St. Jude Donor '15-'16-'17-'18
You have to start from the rear no matter what for disassembly. Put the motor side on saw horses between to boards to split the input shaft. Reverse is inside the extension housing. So you won't have to pull that much apart.
You'll probably need to read this manual before diving in.
Forgot one thing. You will need the gasket that goes between the extension housing and main case. It can only be found at Tremec or the GM Parts department. Tremec would be my choice because it's a battle for the parts guys to find it (at least in my experience).
Don't use RTV you need this gasket to keep the correct end play.
Need help i took reverse apart out, had ever thing in order as i was taking it apart and my neighbor came over with has dog. The dog hit my table where i had all the parts lined up and all my parts hit the floor and all the parts went flying. So my problem is that the manual shows 10 pieces and i have 12 pieces and i can figure out where two pieces go. Is there a diff manual for our trans 6mn?????? i will get a pic, im not home but the part is a very thin bushing and it doesn't show in the manual. Any help Cammin if you have time or anyone thats done this before might remember where these two parts go. 708-244-1409 thanks I can send text pic to show parts.
You could call Tremec and see if they will send you a service manual.
