1998 cranks but no spark
#41
Just read your post. Ever fix problem? I had a no spark once & got stuck on the road. No code, Turned out the wire harness chaffed against metal bar that wrap harness around top of engine under injectors & wraps a 90 deg turn behind intake manifold in front of firewall. Its a tight fitting harness. I took out the metal bar & used zipties after repairing chaffed open wire that was grounding against that bar. That was a cheap fix & AAA paid for the tow home.
#43
I'll take a look , it's hasn't been a top priority.....other things seem to be popping up and keeping me from looking at my wife's vette. I did find
a loose wire that goes to the rear defroster . When I find the bug ...I will post it.
Joe
Joe
#45
I hate it when a good story has no ending.
#46
Moderator, Tech Contributor
Received 2,119 Likes
