Oil pan almost off...how to check for spun bearings?
Old 07-26-2002, 03:30 PM
Phil97SVT
Phil97SVT's Avatar
Default Oil pan almost off...how to check for spun bearings?
I am about 30 minutes from dropping the oil pan, what is the easiest way to check for spun rod and main bearings in an LS1?
Phillip
Old 07-26-2002, 03:34 PM
Phil97SVT
Phil97SVT's Avatar
Default Re: Oil pan almost off...how to check for spun bearings? (Phil97SVT)
I found out what the little gray rubber particles were in the oil filter....They looked like gray solid rock but looking closer they are rubber. I was dumbfounded when I saw this but after dropping the pan and oil pick up tube I found the rubber oring on the pickup tube was cut in half. :nonod: I guess when I assembled the tube and pump the o-ring must have gotten cut or pinched. One problem found, one problem fixed. :yesnod:
Phillip
Old 07-26-2002, 03:52 PM
kp
kp's Avatar
Look for a rod cap that looks blue, look for metal sqeezing out of a rod cap. If you dont see anything start removing rod caps and look at the bearings, dont mix them up :)
If you still dont see anything look at the mains.
If you still dont see anything out of the ordinary, look the best you can at the cylinder walls/pistons.
not much else you can do there, make sore and replace the pickup tube o-ring, that can draw some air in..
Old 07-26-2002, 04:25 PM
Phil97SVT
Phil97SVT's Avatar
I just pulled #8,7,6 and the bearings look fine/not spun. There is very light scoring line on #7. Should I use some assembly lube when I put them back together? Could the broken oil pump pick up tube oring cause air to get into the oil system and cause tapping or low oil pressure?
Phillip
[Modified by Phil97SVT, 8:28 PM 7/26/2002]
Old 07-26-2002, 07:20 PM
C5Noir
C5Noir's Avatar
Phil, a busted o-ring for the pick up tube will dramatically decrease your oil pressure. You typically want 10 PSI/1000 RPM. If you're pulling 6500 RPM ranges with low pressure you could starve the motor for oil.
Old 07-26-2002, 09:33 PM
bparker
bparker's Avatar
Sorry for your misfortune - but this is a great thread.. :D
Old 07-26-2002, 09:58 PM
Matt Gruber
Matt Gruber's Avatar
remember i asked could the motor be pulled out with a chain hoist?
and you gave me a wise guy answer WHY DO THAT?
now you know why i asked :lol: :D
Old 07-27-2002, 02:47 AM
jmX
jmX's Avatar
So is the motor still in the car? Does the pan just drop off without hitting the crossmember? Maybe this would be a good time to replace the rod bolts....is that possible at this moment? If it is, I'd do it. They are infamous for stretching/breaking at high rpms like a heads/cam car might see.
The oring missing will kill your oil pressure, and maybe a chunk of rubber is what killed your lifter.
Old 07-28-2002, 08:51 PM
rwj383
rwj383's Avatar
Default Re: Oil pan almost off...how to check for spun bearings? (jmX)
good question- can the oil pan be removed with motor in the car?
Old 07-28-2002, 09:24 PM
drawbridge oiler
Cruising
drawbridge oiler's Avatar
Phillip
first off, if you have a spun bearing you will see metal flakes and maybe chunks laying in the bottom of your oil pan. if so, grab each rod near the journal and check to see if it's loose. mains are a little different without pulling the caps. usually when one has spun, you will see discolorization and/or metal flakes around the main cap webbing. best of luck. hope this helps. :seeya
To Oil pan almost off...how to check for spun bearings?
Quick Reply: Oil pan almost off...how to check for spun bearings?
