2001 c5z pulsing vibration at 40mph+
How's it going guys?
2 months ago I bought a 2001 c5 z06. Some details about the car:
- 1 owner prior to me
- 50,xxx mile car
- UBBER clean and very well taken care of.
So here's the problem, about a month and a half ago the car had developed a "pulsing vibration" in the floorboard, steering wheel, and seat. It can be heard throughout the car also. It starts at 40mph EXACTLY and continues all the way up from there. It's at it's worse point at 40mph though,(Felt and heard most).
So far, the car is stock and on stock wheels.
Tires:
- Fronts 275/45/r17 Potenzas
- Rear 295/35/r18 Potenzas
Both in brand new condition.
I have lowered the car since buying it but have had it aligned, TWICE! Haha. I have also had the tires checked, and balanced, TWICE! Haha.
The vibration did NOT go away at all by doing the two.
Have had it at the shop but they have no idea what's going on with it.
My guess is wheel bearing, but being my first Vette I have no idea. It's so much different than my EVO and other cars drivelines and such.
The reason I think it's wheel bearing is because when I'm drving down the road, at 40mph+, and it starts to develop, I can turn the wheel to the right and it instantly goes away. If I turn to the left, it gets slightly worse. Going straight it's a constant pulsing vibration that's frustrating as all hell!
So I think it's passenger front WB because when I turn to the right it relieves the pressure from that tire. But that's just my $0.02
Only other weird thing the car does is when I shut it off, it should like the tranny or motor kind of shakes beneath me, so I don't know if a bad motor mount could cause such an issue.
So please, I know it's a lot of reading, and I was trying to be as informative as possible, but I would like to get some more educated Vette owners opinions before throwing money at it!
- 50,xxx mile car
Tires:
Assuming you've checked the lug nuts, a way to check a wheel bearing is to put the wheel and tire in the air off the ground and grab the tire with your hands at opposite sides and see if you can get movement.
Could also be an internal tire separation of tread belts causing it. It happens. Hard to see but with the tire in the air you can rotate it and see if you notice anything.
Also you could have lost some wheel/tire weights.
Mine has had that for years. Just rode in a stock c6z yesterday and it was doing the same thing. This wasn't until about 85mph though.
I had the exact same issue you have. I raised the front passenger side tire off the ground, grabbed the tire at 3 and 9 position, and at the 12 and 6 position and pushed/pulled like crazy, wheel/tire didn't budge. I even placed a pry bar underneath the tire at an angle and pried up, lowered down, etc., nothing seemed loose. So at that point, didn't think it was a bearing. I had another member PM me and suggested it was the bearing even tho I could not find anything obvious with my testing. So, I bit the bullet and replaced the front right wheel bearing myself, problem was solved! I hope this fixes your problem too! Good luck!
I have the same problem except I get the pulsing vibration at 60 mpg. I was going to have the tires balanced just in case but I suspect it is the wheel bearing as well.
Awesome! Thanks for all the insight guys! I will probably just buy a wheel bearing in hopes that from there on out it'll be fixed! Haha *Fingers crossed*.
Bump! Have taken to multiple tire/suspension shops and most can't seem to find squat. I have notice that if I turn my wheel (full lock) to the left then there's a loud screeching noise coming from the front passenger side. Sounds like a squeaky brake!
Pull the tire and caliper and spin it by hand. You can hear and feel it if its bad. Sometimes the tire doesn't move.
Ended up being a bad tire for me. I took the car to several tire places and they always told me it was fine. I ended up stopping by the dealer and asked them to balance the tires and sure enough they could not get one to balance correctly, replaced the tire and problem went away.
Did you ever replace the wheel bearing back in August? I have the same issue I believe, except mine is at around 80mph. Fairly sure its either a tire or wheel bearing. I also have new tires so I'm leaning towards a wheel bearing. I think I can eliminate the driveline because pressing the clutch in does not make the noise stop.
St. Jude Donor '14
Do not guess
You're on the right track with the wheel bearing, but to answer your second question, the rattle type noise under neath you when you turn the car off is normal. It's the pilot bearing. If you hold the clutch down when you turn the car off the noise should go away. Tons of threads on it, no issue or problems. Just an annoying noise. I've gotten so used to holding the clutch in when turning the car off that I don't even think about it.
