ABS, Traction Control, Active handling warning light on.
These warnings came on about a month ago and went off. Last week they came on again and stayed on. I pulled the codes and it showed 28 TCS C1214, Sol Valve Relay Contact or Coil CKT open. Has anyone had this problem and what is the fix? Thanks.
CF Senior Lurker
St. Jude Donor '14-'15-'16-'17-'18-‘19
I believe in the Beer Fairy
MacNH
1214 is a sure code that your ABS/TC module has failed. If your C5 is 1997-2000, you will have to find a used module somewhere. They are getting hard to find and very expensive. If your C5 is 2001+, you can send off the module to ABSfixer. I sent mine a few months back. $150 and about a 7 day turnaround and all is well again.
MacNH
MacNH
Look at ABSFIXER site. He has info on removing the EBCM.
https://www.absfixer.com/how_do_i_remove.php
I had mine fixed here
http://www.ebay.com/itm/CHEVY-CORVETTE-EBCM-ABS-MODULE-REPAIR-SERVICE-2001-2004-/301237003311?pt=Motors_Car_Truck_Parts_Accessories&hash=item46231fe42f
I haven't read this whole thread but he says he can fix them..
http://forums.corvetteforum.com/c5-g...abs-units.html
I just read it but John at Caspers said he fixed one and can do others and a few others said they have fixed a few. So it's possible depending on what's wrong with it. I seen your post in there to just got done reading it.
Don't want to take the chance on fixing it myself. If I could get one already refurbished reasonably priced, I could get the job done in one day. Then I could get my unit refurbished and sell it or keep it as a spare.
Just an FYI. You CAN drive the car without the EBCM installed. just cover the pump portion of the system with plastic to avoid getting a lot of road crap on it. You won't have TC or AH or anti lock brakes but you don't have those now with the C1214 code..... Brakes will operate as non-anti-lock.
Driving without the module installed is the same as driving it with the code. Either way your TC an AH is not working. Covering the pump and wire connector with plastic is going to keep things safe as long as you don't get crazy around water. But hey! it's ultimately your call.
I drove mine 300 miles with the module off.
what do you do when you drive a car without abs built in the car? abs on a downpour wont do anything you hydro plane your ****ed you skid out of control your ****ed..your car though good luck lots of options for you and very easy ones
