2004 C5 Trans / Diff fluid change ... The fluids to use ???
Old 08-27-2014, 06:13 AM
UZISOLO
UZISOLO's Avatar
Default 2004 C5 Trans / Diff fluid change ... The fluids to use ???
Changing Six Speed Manuel Transmission and Rear end Diff Fluids .... Need help on the best brand name fluid and part numbers / fluid type / How much per unit ... 2004 C5
Old 08-27-2014, 09:53 PM
spdislife
spdislife's Avatar
I use Amsoil. You can go to their website and checkout the prices. Their only product I'm not completely pleased with is their DOT 4 brake fluid
Old 08-28-2014, 12:52 PM
RedZMonte
RedZMonte's Avatar
When i did mine i used Vavoline Dex III (trans) and Valvoline Synth 75W90 (allready has LSD additive) For the rear end, both off the shelf at Checker/Oriley parts store. You can also use the OEM manual trans fluid from the GM dealer (iirc its synthetic), DO NOT USE DEX VI!
IIRC the trans took 4-5 qts and the rear took 2 qts
Old 08-28-2014, 01:41 PM
skip1980
skip1980's Avatar
Just did this a couple of months ago. Used Amsoil in both. Severe Gear 75-90, bought 3 quarts used just over 2. Used Torque Drive ATF sold in Gallon jugs, didnt used the whole thing. Seems good so far.
Old 08-28-2014, 03:14 PM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,260 Likes on 1,055 Posts
another vote for amsoil... it will cost about $100 total for the gallon of atf and 2 bottles of gear oil... I have changed mine twice in the last 3 years (8k miles) and have had no issues
To 2004 C5 Trans / Diff fluid change ... The fluids to use ???
Quick Reply: 2004 C5 Trans / Diff fluid change ... The fluids to use ???
