04 z06 hard to start after sitting
I recently purchased an 04 Z and have noticed that after it sits in the garage that I have to crank it dor about 4 seconds before starting. It runs great, no codes other than 2 on the hvac. After it starts I can shut it off almost immediately and it will start right back up as it should. I've checked the coolant temp sensor and it's reading correctly. Any suggestions on tracking down the problem? I'm wondering about the pressure valve in one of the tanks but I know very little about it, just read on another thread about this creating a similar issue.
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
The battery is strong, it doesn't struggle to crank at all, just takes a bit before firing. Is there a simple way to check fuel pressure at the rail to see whether I've got a leaky injector?
You need a fuel pressure gauge that fits the Schraeder valve on the forward end of the driver's side fuel rail. Note that pressure will drop over time normally. You need an injector test kit if you want to check for leakage.
Or pop the fuel rail up with all the injectors still attached and lay clean toweling/rags under each one, then turn the key to the "on" position.
Ok I've picked up a fuel pressure test gauge from O'reilly auto but the loner tool has been well abused and leaks around the connection between it and the fuel rail. I connected it and cycled the key several times, pressure read around 50psi but dropped quickly due to the leak. Given the leak I think the reading was probably in line with what it should be. I'm guessing if I could get a good seal this would allow me to test the pressure valve in the tank, would his be correct? I did also pull the fuel rail and put towels followed by notebook paper down underneath them so I could check for any leaks. After an hour two of eight have a tiny spot on the paper underneath the injectors but I suspect this May have been residual on the end of the injectors righ after pulling. How long should I leave them out to test for leaks?
Take the loner tool back and find another one. Try an AZ, or Discount, or maybe NAPA AP store. Get either a loaner that doesn't leak or a buy a new one. They're not expensive. You should be seeing 58 psi (~) and it should hold steady for awhile.
Thanks, I plan to borrow one from a coworker on Tuesday. I did hook up the bad one to the rail after reinstalling the injectors and had 58psi when running so pressure is good.
If this issue turns out to be a faulty check valve, the bad news for you is you're going to have to drop the driver's fuel tank and replace the fuel pump module assembly. That's where your check valve lives (as well as the fuel filter) and it's part of the assembly. Not available separately. Pricing on the unit runs around $200 to $350-ish depending on brand and where you buy it from, etc.
St. Jude Donor '14
Leave the gauge hooked up. Let the car sit a day or two, however long it normally takes to have the hard start problem. Check the gauge reading before turning the key to on. I bet it is 0psi. Cycle the key to on, do not crank it. What does it read? Cycle the key a couple more times until the gauge reads 58. Now start it. If it starts right up, the check valve is bad. I had the exact same problem.
