Rebuild or buy New Rear Differential
High mileage c5 differential leaking I think from driver side output shaft and main o-ring seal where xmission and differential meet. Just curious as to the cheapest way to fix????
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,,,,,,,,,,,,,,,,,,,, If its a solid rear and it not making any strange noises, I seriously recommend doing ALL the work your self.
If I can do it, anyone can. I did the entire power-train up-grade on jack stands.
Here are three post for some light reading:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
If you have a high mileage C5,,, make SURE to change the differential clutch packs and beleiview springs along with the seals.
Anything above that level of rebuild as outlined in the links, requires SPECIAL tools for diff alignment
BC
Bill
BC
Bill
Let me tell you what I can do with a set of jack stands and a jack, Better yet. Let me show you.
I have the utmost confidence that anyone here can fix these cars.
