My 402 stroker surprise surprise!!!
#61
Still waiting on my motor to be put back together. New crank came in last week. Everything dropped of at machine shop thurs morning . Builder going out of town tomorrow until next monday.so maybe ill get it back in about 10 more days.
#63
the motor has 1000 miles on it since it was built , engine builder is installing new bearings and new crank, but hes reusing the 1000 mile rings. Is this ok or is he giving me back a motor thats going to be a problem?
thanks
thanks
#64
St. Jude Donor '14
Make sure the builder pressure flushes all the oil passages really good. Don't want to start the engine and start pumping old debris threw it. Same goes with the oil pan.
#65
Received 1,194 Likes
St. Jude Donor '15
I would let the builder decide personally. He's been good about fixing issues and I'm sure he doesn't want to create another one by saving the cost of new rings if he thought there was a chance of them not working
#66
I thought someone would have told you no already, but I have actually done exactly that and it did not create any issues.
Eds a good man. Not many would do what hes doing.
#67
Received 3,043 Likes
St. Jude Donor '05
Should be on the road soon hope your luck turns
Dont use straight 50w wow. Its a car not a compressor
#69
Uneducated overachiever
#70
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any more up dates???
BC
BC
#75
mike v
Just My .02,, But the old GUY here ( Member of Rouch Racing ) say's never re-use:
Rings, Bearing's, Gaskets, or Rod and Main Bolts. I agree
Good luck with your new Engine.. Bet its fun to drive though.
#76
UPDATE
UPDATE
Well i got my car back last week it has about 150 miles on it since rebuild.He installed new oil pump,bearings, 2pc oil pan,gasgets, New Callies compstar Crank, the car now has 5-30 oil ,holding 40psi at idle 55 psi going down interstate, its running great, It wound up costing me $1,600 out of pocket . he said i could use the old crank but it would be at 30 thousands , And if i was going to keep the car i would have never been happy with that inside my motor. So i feel i was very fortunate that Ed did what he did to help me .
As for the 50wt oil, he says he built the original 402 loose so it needed that to get the pressure up, I say it was built to damn loose and i think the damage started on the dyno when he broke the motor in and tuned it ,
Still waiting on reciept for the $1000 crank, And he says he sold the old one.
UPDATE
#78
St. Jude Donor '15
I'd push for the receipt on the crank, just to be sure.
Sounds like it is working out though.. did he end up reusing the rings? No issues?
