Digital display on instrument panel is out.
Cruising
If this has been posted could someone please help me find the post, I couldn't. Everything is working properly on my instrument panel except for the digital display at the bottom. It has gone blank on me a couple of times before but it came back on. As of this time it has not come back on so I can't see codes it might be throwing. Any help or explanations on what I can do would be greatly appreciated.
Thanks!!!
Thanks!!!
Looks like the display or the circuit board in the IPC has "gone south". I have dealt with several of these issues.
If it were me, I would get a replacement and just swap it out. Make sure if you have HUD that you get a HUD IPC. They are different.
You will have to have the mileage reset but by replacing the IPC yourself you can afford to have the mileage reset at the dealer or other shop.
Here is how to access and remove the IPC and also a link to show you what the inside of the IPC looks like.
http://www.vetteessentials.com/instr...zel_howto.html
https://www.corvetteforum.com/forums...post1570380674
Forum vendors are a reliable source for an IPC. If I can help you in any way let me know.
Cruising
Here is how to access and remove the IPC and also a link to show you what the inside of the IPC looks like.i
