B&B bullets or SLP loudmouths
I have it narrowed down to these two for now i guess. Which do you guys prefer an which one is deeper. Also if you have a different exhaust that is loud or deep that you know of say it maybe i haven't looked at it yet. Thanks for your input
St. Jude Donor '14
If the engine is stock with exhaust manifolds and cats, then either would work. If not, I would advise against both. The car will be extremely loud and have a very annoying drone/resonance. Buy LT headers and an off road xpipe. You'll get much better performance and a more powerful sound thru the stock mufflers.
I have B&B Bullets, and believe it or not they're quite sedate until I put my foot down. Also they only droned when I still had the stock H-Pipe. Once I cut that piece of trash out and put in a proper Corsa X-Pipe, the drone disappeared.
The bullets will be deeper than the slp's. If you have a cam, it will be more pronounced with the slp's. I have had them both. My pick is the slp loudmouths and yes they do DRONE! A partition helps with that though when you have a frc. I just sold my GHL's to go back with SLP's. Both sound good, but I wanted to hear the cam lope more, so I went back with the slps.
