fast 92mm what throttle body
ok picked up a fast 92mm intake manifold so know looking for a throttle body to use (Not a NW 92mm) looking for a GM
was told a ls2 but witch one? ls3/ls7 are also 90mm can they be used?
silver blade, gold blade??? confused over this
help please!
help please!
Basically. Just be sure to look for part number 12570790 OR if buying a Delco unit, use 217-1617. Silver blade. Beware false or misleading ads. Look for the specific part number.
Also use the Racetronix adapter harness, not Casper's. Better harness and same, or even slightly less price.
so then this one will work
Awesome! thank you for the part numbers!
http://www.amazon.com/ACDelco-217-16...ype=automotive
This is intersting as i need a TB as well. I already know LS2 but my concern is price. Im a little confused too. So is that $300 for a NEW and out the door hand ported and polished TB? Or is that the price of sending one in and back?
Take a close look at the flat connector body end-view at the top of their picture and tell me what you see. The two cavity positions (second and third from the left) that look kind of "yellowish"? That's daylight showing through, allowing moisture, water, dust, debris, etc, thereby promoting corrosion INSIDE the connector, because they're too cheap to close of those two holes with the correct plugs made for that purpose. What would it cost them/ Maybe .0001 cent each?
I have had nothing but positive experiences with Racetronix harnesses, hardware, etc and they also usually undersell Casper's by a few bucks in most cases. They continue to make high quality products at their manufacturing facility in Canada, and I will continue to recommend them every time.
