C7 wheels on a C5
Torch Red Fire 21 (03-03-2024)
Would the c7 z51 19/20 wheels fit a c6 z51 without clearance issues?
Would it look appropriate? Or need lowering?
I apologize for posting a c6 question on a c5 section yet I figured you might know the answer.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Yes they bolt right on. Over all tire height is the same of that on the C6 so up to you if you want it to be lowered or not. It would not change how the car sits as it is.
JerriVette (08-18-2018)
Thank you Anthony at LG Motorsports
Do you think a 18x10.5 56mm backseat would work on a c7? I know this is brining a thread out of the dead and kinda asking a diffrent question. Hoping someone knows the answer. I know the c5 z0 wheels are 18x10.5 58mm correct?
Here is the calculator. Put the stock C7 and new wheel data into it and it'll give you the differences.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
On the front it would extend into and out of the wheel well 25mm or 1". That could cause issues with suspension clearance and tire rub on the fender lip.
Thanks. I have coil overs so my suspension is pretty easy to adjust and it's really stiff now. I'll use that calculator from now on!!!!
Assuming on the rear, compared to the stock C7 wheel that size would extend 29mm more out of the wheel well. That's over 1-1/8". It would also extend 17mm less into the wheel well. So, you'll certainly be fine clearing suspension and the inner wheel well, but it may stick out of the car too far and you could have a tire to fender clearance issue when the suspension compresses.
18" front / 19" rear or 19" front / 20" rear
I have a stock C5 Coupe:
Front 17x8.5", 58mm offset = 7.03" backspace
Rear 18x9.5" 65mm offset = 7.81" backspace
Looking to put on the the Z51 package size wheels:
Front Wheels: 19" x 8.5" +56mm offset = 7.45" backspace
Rear Wheels: 20" x 10" +79mm offset = 8.61" backspace
The difference in the rear wheel offset and backspacing is what has me worried.
I put OEM C7 Z51 wheels on my C5 using DRM spacers and ARP studs to make the rears fit. Fronts are a direct fit.
No adapters or spacers are needed up front.
I did the same to mine only with C6 wheels which are the same 18 / 19 inch size and offset
Have opportunity to purchase 2014 base wheels and tires intending to put on 2001 C5
Hi, do you have the big brake kit (c6z06) calipers? Im having a hard time finding the right wheels, yours look great, and I dont mind spacers in the back.
